TwinTurbo.NET: Nissan 300ZX forum - the defi is tapped in between the cluster and the ECU?
aliaZ
on November 14, 2012 at 12:11 PM
ECU not seeing Vehicle Speed
posted by Carlos Ramirez
on November 14, 2012 at 11:12 AM
I'd try disconnecting the defi and see if that fixes your issue. If it does, the defi is corrupting the signal before it reaches the ecu. If it still doesn't work, then look for a connection fault between the defi and the ECU connection.
Carlos Ramirez
11:12:27 11/14/12
the defi is tapped in between the cluster and the ECU? -
aliaZ
12:11:42 11/14/12
Re: the defi is tapped in between the cluster and the ECU?
Carlos Ramirez
12:17:52 11/14/12
If you replaced the efi harness and de-pinned the connector
ShakaShaun(Denver)
18:06:35 11/15/12
Same here, easy to do. (n/m)
Fast300
15:36:07 11/17/12
